MFA Antifreeze?
cm1
Does anyone have any experience with MFA fluids?
I'm thinking about going to Big O Tires to get my engine coolant replaced, and it looks like they use MFA-brand (MFA OIL Longlife Pre-Mixed 50/50 Extended Life Antifreeze & Coolant): http://lubeadvisor.mfaoil.com/en_US/equipment/mirage_es_1_2_FawEeHq4t?q=2014+mitsubishi+mirage
This is apparently an OAT (Organic Acid Technology) coolant, from an email I received from them.
Is this suitable for use in a 2014 Mirage? Mirage's manual says to use "Mitsubishi Motors Genuine Super Long Life Coolant Premium or equivalent" and equivalent means "similar high quality ethylene glycol based non-silicate, non-amine, non-nitrate and non-borate coolant with long life hybrid
organic acid technology"
I found this information on MFA's coolant: https://www.mfaoil.com/wp-content/uploads/2019/12/sds-longlife50-50antifreeze.pdf & https://www.mfaoil.com/wp-content/uploads/Longlife-Pre-Mixed-50-50-Extended-Life-Antifreeze.pdf
I'd appreciate any responses!
Don't know about the MFA deal, but the Big O part certainly warrants a hard pass IMO.
Have you had bad experiences with Big O? I've been to my local shop and they've been great so far.
Horrible experiences. To make a long story short, I had a NTB tech (same company, just rotates names back and forth) tamper with my car and then try to upsell me. I was watching in the window and witnessed the whole thing.
However, experiences can differ depending on the management of a specific location.
I was later informed by the regional manager that when they fired the tech, after severall other complaints, he punched the store manager.
Try googling Big O and/or NTB. I doubt you will find much good.
It's a typical private label OAT based all makes all models type antifreeze, it'll be fine in a 2014 Mirage and won't change the colour of the factory coolant.
