Metric grease fittings
SE British Columbia, Canada
Looks like I busted a right angle grease fitting
on an AC Delco lower ball joint. To unscrew the fitting from the ball joint I had to use a 10 mm wrench. A 3/8” wrench was too small. Does this mean the thread is going to be metric? I have a English sized grease fitting to take its place and the threads seem to mesh but hard to tell. There is not much room to start the threads on a new grease fitting so I was thinking I should get a M6 to check it out. Any opinions out there? Thanks.
Thanks very much. My local hardware store had a pack of assorted 6mm fittings and I was good to go. There was not much room to get it started but it went in. The funny thing was the wrench to turn it in was 3/8", probably because it was just a cheap pack labeled Lubri Matic. I'll pick up a kit. I can always give it to my son.
One other thing I found is that the 1/4” 28 taper and the 6 mm fittings are almost the same size. There are also self tapping fittings that probably negate this issue. Using a calliper tool and measuring across the bottom of the threads of a 6M fitting yields 6.0 mm. Measuring across a 1/4 inch 28 taper yields some closer to a quarter inch which works out to 6.3 mm, very close to the metric one. Here are some shots of the digital calliper tool. Enjoy.
