Here’s my used oil analysis of Redline 140wtNot sure what the exact year was but ford switched from a 140 to a 90 in the 10.5” sterlings somewhat recently with no change to the diffs or application.
50K miles
2018 Ford F250
I run 75W-140 in my F150 and F350 and the Toyota Tacoma ,,, the 75W-140 in the Toyota is over kill but then over kill is underestimated.Not many applications seem to call for them, and the folks that do have them never seem to test them.
However, I do have to ask, do you have an application that calls for a 140 grade gear oil? The 75w90 HPL is robust enough that Richard Petty’s car haulers use it with no failures, that seems pretty stout to me?
You could, but your interpretation will likely be different than someone else’s, and because of different reasons. I should have the pour point and Brookfield data for the 6 newer oils soon.Not sure how to really interpret the data. Can one put these in order, if possible?
SynpowerWas the Valvoline listed on here the white bottle/blue label (conventional?) High Performance 75W-90 or the SynPower 75W-90. Looking at their packaging, both contain a limited slip additive.
If we need some results on SynPower, just bought 12qts to do some diff series on and could send in some to Blackstone for a VOA. Also have some Amalie 75W-90 (w/o LS additive) that I could send.
...had about a 1/4 of a quart of John Deere GL5 75W-90 that I could've sent in but I mixed it with 1/4 quart of the leftover Amalie I had left for the 54D mower gearbox (whoops!).
Still tuned ...Update on the Brookfield and Pour Point tests: it appears I had not clearly communicated to the lab which tests we needed run, so they were not accomplished with the data above.
Great news is, the lab is very meticulous and still has the remaining amounts of the quarts donated by @ford250 and @SNWMBL, and will run the tests over the next coming days. So, due to my error there will be a delay, but the lab is coming to the rescue! Stay tuned…
Still waiting on lab. As posted earlier, I asked a big favor from the lab for all this testing, so we’re at their mercy (grace?) awaiting results. Considering each oil had testing that amounted to at least 75x what each quart cost, a little wait isn’t that bad. In reality, there’s already plenty of data about the 11 gear oils in this thread for the 99% of people who live outside the Arctic Cirlce to make their decision.Still tuned ...
When you do the Torsen, you could capture the Amsoil in a clean (new?) container and reuse it?Trying to apply this info to my current situation.
Money has gotten tight, and rear diff on my Transit has gotten leaky. Only 82000 mi. In a semi-perfect world I would install an Eaton TruTrac Torsen rear diff, and use appropriate fluid ( no friction modifier, synthetic NOT preferred???). But must fix the leak, and replace the factory fill (82k), no Torsen this year.
Here are factors I considering.
Ford spec is75w85
Tall roof Transit van, near 10 ft tall, though only 7500 Gross weight (typical), but lots of aero drag
Most mileage is highway, but considerable off-road (10-15%)
Does anyone know how different Mobil 1 is from Mobil Delvac 1?
I may have to use a fluid a local shop will accept (or source). Lots of Valvoline lovers here, but I’m not…though for gear oil, not a hater; though not overly impressed with its performance in this shootout.
I really liked the Amsoil SvG, but considering I might be looking for only 12500-25000 mi solution before swap to Torsen, maybe it is overkill. As much as I like HPL, I can get Amsoil for less (though not near as cheap as Delvac),so for the moment will rule out HPL (at Torsen time, will reconsider).
It pisses me off that a year ago I would have done this myself, now, “old-man-back” makes me a target of shops (not just dealerstealers).
Or, on the other hand, think of it as a relative comparison. If Valvoline passed some of the most intensive tests available (multiple vehicles have to run 200k miles & then pass tests), think of how great the oils that performed objectively better really are?Kinda disappointed how poorly Synpower did since it’s on the Military approval list.
Yupper! 75W-140 in the rear diff of my 2021 Ram with 3.92 LS75W-140 is common in anything offroad, or almost anything Dana - although Nissan - which in some cases uses a Dana diff - has seemed to go back and forth between 140 and 90 on the same diff - depending on the year - so who knows.
I recommend 75W-110, especially in differentials that are not much different than before the SAE J306 gear oil specification was changed.Can I ask for concurrence (or not) with my interpretation of the original @SubieRubyRoo results, for use in Ford Transit 250 camper van (some off-road, no towing), and new-to-me older Subaru 6-cyl automatic with 2 diff’s which each take 75w90 (@80k, it’s time to see if the diffs still have factory fill).
Local Subaru indie shops love Motul.
If North Central TX temps for me will ALWAYS be above 0F, and almost always above 0C, is there any reason to choose the Motul over the Amsoil Severe Gear 75w90?
Pricewise, HPL up there, as are OEM Motorcraft 75w85 (yes, 75w85) and Subaru HPGO. Also Motul expensive. Except for coldest weather, I don’t see a downside to the Severe Gear 75w90 (I don’t think I need to pay shipping, and would buy short-term “subscription,” to get lower pricing). That said, @Pablo keeps pushing the 75w110 in these forums. I wonder if Amsoil “thinned down” the 75w90 to make room for the 75w110? Though Subie’s tests appear to be recent version of SVG.
Somewhat beneficial to use same fluid in both vehicles, unless good reason not to.
Pablo’s sold a lot more Amsoil than I ever will, but that doesn’t mean I won’t recommend it… because it’s really good.Can I ask for concurrence (or not) with my interpretation of the original @SubieRubyRoo results, for use in Ford Transit 250 camper van (some off-road, no towing), and new-to-me older Subaru 6-cyl automatic with 2 diff’s which each take 75w90 (@80k, it’s time to see if the diffs still have factory fill).
Hmm. I would have no scruples about buying Ravenol.Yeah I’m reaching out to the lab to see if they had captured that data and didn’t include it. Hope they have it.
No real surprises IMO other than pedestrian results from Ravenol…
