Measuring Gasoline Weight
Check my math:
Gravity = 0.65 - 0.75 grams per milliliter
2.5 gallons = 9463.53 milliliters
0.70 grams X 9463.53 milliliters = 6624.471 grams
6624.471 grams = 233.6713 ounces
233.6713 ounces divided by 16 = 14.6044 pounds
2.5 gallons of Sinclair gasoline weighs 14.6044 pounds
Is that right?
SINCLAIR PDF
Yes your math works...well to sig figs it would be 15 lbs, but yes the math work.
In my head I would have said 2.5 gallons of water is about 20lbs, and 3/4 of that(.75) is 15lbs, so 14.6 makes sense(that's using the 8lbs/gallon rule, which isn't quite correct but makes for easy mental math).
Water is roughly 8#/gallon, gasoline is roughly 6#/gallon. That's the easy math. :)
Check my math:
Is that right?
SINCLAIR PDF
I guess gravity is a term that is used in the industry but a more familiar term is density. Gravity, which is really specific gravity, in this sense is the density of gasoline divided by the density of water. Nice to see someone using metric. 2.5 gallons x 6.07 lbs per gallon would yield 15.2 lbs. The gravity number used seems a bit light. I’ve seen it described as .72 .
Here is something on specific gravity.
