Yesterday I did a partial atf change on the wifes vehicle(Mazda Tribute 160 k).A few weeks back I was driving the vehicle and noticed the shifts and torque converter lockup were not very smooth.
So I got a gallon of Mercon-Supertech brand and waited till I had a pretty day.That day was yesterday.I opened the drain plug and let it drain about 20 minutes.The fluid drained was pretty dark and appeared somewhat thicker than ATF usually is.Tightened it back up.Thank the lord for whatever engineer put in that drain plug.AFAIK the transmission has not been touched we bought the vehicle at 80k and it has been a darn good purchase.
I also changed the oil filter while I was under there as this was the mid point of the extended o/c.
I cranked the vehicle and backed it down the ramps and let it idle a bit,checked for leaks and took it for a drive.The shifts and converter lockup was much improved,very smooth.
A good bit of improvement for not much money or time.
I just hope all the old tales of fluid changes in an auto transmission causing problems don't pan out in this case.Esp since I only changed out a third of the fluid capacity.
Keeping the fingers crossed.LOL
