So far so good. Did a double D&F after 40k on AMSoil, 47k total. The MaxLife is very smooth. Some shifts seem stiff, but it's settled down after a day. I'll check back in after a few more days, but so far so good.
I plan on continuing w/MaxLife, 1 D&F a year. The only reason I did a double is I was changing brands, both with the AMSoil and with the MaxLife 2 years later. A double D&F really does not make sense from a maintenance standpoint, since you are drainging half fresh fluid. A single service yearly insures the fluid coming out has some miles under it's belt. (is that a good term???)
btw- the deposits on the mag drain plug were VERY minimal. Less than I am used to with the CRV. Maybe 2mm max.
