Marine Grease
Philadelphia,Pa. U.S.A
Can anyone recommend where I can find marine grease other than the from manufacture Quick-silver(mercury)
The greases I need are as follows: 2-4-C Marine lube # 92-825407a12(propeller shaft), Gimblebearing Lube #92-8250552a2(Bearing lube), Special lube 101 92-13872a1(steering lube). Suggestions on substitute welcomed.
Bill, I know that I responed to you in your post in the Grease Section that you should really just go with one grease. I know that I use the OMC Tripleguard grease for the steering, propeller shaft, lube points on the motor and the spark plug boots. I would not worry about the different specs, Mercury wants you to buy their five differently labelled greases, that all basically do the same thing. Do you have any boating stores in your area like Boater's world, Westmarine or Boat US? If so, let me know, I'll let you know what product to get. -Joe
