Originally Posted By: 84zmyfavorite
Depends, on engine, manual trans ratio, differential ratio(ring&pinion) size of tires, Inflation of said tires, uphill down hill, snow, condition of clutch, etc
There you go, there are so many variables there is NOT one method that's correct...
For instance take my '69 428(that's 7 FULL litres for you metric guys), 4 speed Fairlane... Big engine should be easy to get going right?? WRONG... It has a close ratio trans with 2.32 1st gear, 3.00 rear ratio and a 670 CFM carb, if you don't ride the clutch a bit(it's 11.5", can stand a lot of abuse), when starting out the manifold vacuum will drop and she'll fall on her face(no EFI here to make things easy)... Be aggressive with it and it'll pull off without issue, be really aggressive and it just sets there making tire smoke...
It really needs more 1st gear ratio and I should reinstall the original 3.50 rear end, would make it easier to drive... Maybe one of these days...
