I am working on a 78 Jeep CJ7 with a three speed manual transmission. The Hayes manual calls for a GL-4 lubricant in the transmission, and a GL-5 lubricant in the transfer case and differentials. I went to O'Reillys and they had a gallon jug of "Master Pro" gear oil. The label indicates that you can use the oil in Man transmissions, differentials and rear ends. It is a GL-5 but the label also indicates that it can be used in place of a GL-4 lubricant. I took the product at it's word, bought a gallon and have used it when I changed out the lubricant on the transmission, transfer case, and both differentials. Now reading this forum it is not clear whether I need to put a GL-4 only lubricant in the transmission or not? Can anyone make this a bit more clear cut?
