Car: 2004 Pontiac Sunfire 2.2L Ecotec 5 speed manual Getrag transmission. 144,000 miles on original clutch till now.
On Friday my manual transmission gave out... on the way home from work my clutch pedal stuck to the floor as I entered the freeway. I had to pop it back out with my hand. Before that however, on my way to the freeway I noticed the transmission was "catching" the gears as soon as I let off the clutch instead of providing a cushion for getting into the next gear as I depressed the clutch. Something was definitely wrong.
Anyway, upon exiting the freeway the clutch gave out completely - it wouldn't let me shift gears even with the clutch in so I had to match RPMs with speed to get it into gear.
Had my car towed on Monday to an automotive shop. The AAA tow truck guy noticed my hydraulic transmission fluid was empty and full of black [censored]. Also noticed a pool of fluid (oilish looking) under the car that wasn't there before.
In the end the automotive shop found out that the clutch slave cylinder was leaking. Being that I had 144,000 miles on the car they also suggested replacing the clutch. Total bill: $1444.28.
Mechanic said that they had to drop the transmission to get the clutch kit in hence the $500 labor cost. The "clutch kit" was $871.93" - brake fluid also had to be replaced for $5 only.
Now after it all: The clutch pedal is like 3 times easier to depress/press, and there is no jerking or rough shifting from gear to gear! It is actually smooth and very very nice! Ever since I bought my car it had an extremely sensitive clutch - very difficult to drive. Now have to get used to a new one all over again.
Questions:
Was the price fair?
What would cause this to happen?
Suggestions/comments/anything welcome!
Thanks!
-Paul
Questions:
Was the price fair?
Thanks!
-Paul
