JHZR2
Staff member
Hello,
I would like to drain my radiator about yearly to replace part of the coolant and keep the systems clean. While at it, Ill likely waste a gallon of distilled water on through, to fluch out any junk in there, before replentishing the coolant.
The problem is this- on most cars, the radiator stopcock is located in some inconvenient spot, ad when it is opened, it dribbles coolant all over something below, so tat it does not drain from one single place.
I just had this experience on our integra this evening...
It turns out that our integra has a bad upper radiator hose. Honda has to use the poorest, lowest quality rubber parts of any manufacturer. We have two other 94 cars, a 96, 97 and a 98, and all of them have perfect OE factory hoses. The acura's is junk, though it only has 186k miles, compared to two of the others which are over 200k. It has only seen OE honda coolant.
Anyway, I was doing a drain and learned of the bad hose when refilling. SO, Ill have to drain and refill again. Id like to get more into my collection drum (nearly 2ft wide), and less onto my driveway, when doing the job.
So, what do you reccomend as far as draining radiators, to manage the spills and general mess, and maximize the amount of coolant collected below?
Thanks!!!
JMH
Thanks!!!
JMH
