I was thinking of adding either a magnet on the oil pan or a smaller one on the end of the mag drain plug to make it stronger(Mag. plug from Pepboys and not very strong). I have read and searched here on the oil filter ones, but they seem to be expensive and you have to replace it everytime you get an new vehicle, plus it is still up in the air if they have any effect on a metal bypass system. I also read that a magnet on the oil pan will magnetize the entire pan even when you take the magnet off, but I would rather live with that then have a filter magnet that messes with the internal parts, plus it has been said that you can break the magnetism on the pan by hitting it a few times. So, I am thinking the best rout is to either put a magnet on the pan near the drainplug, or to get a smaller magnet to stick on the end of my drain plus to make it stronger, so can you guys tell me where to get some magnets that can be used in automotive applications. Will probably add a few smaller ones on the end of my trans and diff drain plugs too. thanks
