Mach-E front motor dead at 33.5K
SEC Country
TL: DR version: front motor is dead and will need to be replaced, waiting on parts from the mothership in meat chicken (say it fast, you'll get it).
I was going to post the video from the service advisor at the local Ford dealer but you can see my phone number in the work order at the start of the video, and the video isn't downloadable to edit it out. Maybe there's someone here smarter than me that can figure out how to do it.
There's motor ATF coming out of multiple joints including the PCM connector and they can hear the grinding noise my wife experienced, so it's got to be replaced. They had about 5 or 6 PO codes on the work order also.
Browsing the Mach-E forums it seems there have been a spate of motor failures. I haven't seen the same on the Lightning forums, so it seems maybe this is a Mach-E issue and not a Ford issue. In our case it's never seemed quite right, there has been a whine at certain RPMs that didn't sound right to me, I actually asked them to look at it when it was back for a software recall about 6-9 months ago. They said they couldn't find anything wrong.
The motors are warrantied for 8 years 100K. The buyout on the car is $19K at the end of the lease and with the increase in used EV prices recently it's looking like a better deal to keep it. The results of this repair will be informative as to whether we will keep it or not though. If the motors are quiet when we get it back then I'll lean towards keeping it. If it still whines at certain speed ranges I'm almost certain to dump it, I don't want recurrent motor issues, 8/100 warranty or not.
One has to wonder when the EV teething problems will be solved. I remember a thread from several months ago where EV advocates were arguing the virtues of EV vehicles vs ICE vehicles. The EV's having far fewer moving parts to break.......... Sounds like both will have continued problems for a long time to come.
Tesla has mostly solved their early motor issues with coolant leaks and so forth. The aftermarket has moved in to help with the early motors, as well, with coolant bypass kits. There seems to be no ill effects for older Model S owners who have done the coolant bypass.
Perhaps the other manufacturers are still in the teething stage on motor issues.
Everything breaks, its a matter of what breaks and how often. With significantly less moving parts, EVs theoretically should be less maintenance overall. However they will still have problems like any other vehicle.
The hope is that the replacement will have the manufacturing upgrades necessary to ensure reliability. I know that Ford's replacement transmissions (for pickup trucks) nearly always include the latest mods. So they don't have a repeat warranty claim.
A shame really, I gave up on them years ago. Even though I won't own an EV this just reinforces my reasons why not to own another Ford. Kudos to the OP for leasing it.
Given Ford's track record of parts availability, it wouldn't shock me if the motor becomes discontinued after a few years.
They've already diverted their attention and resources to the next cool model to be released. That seems to be how the Big 3 operate.
Consumer reports 2025 reliability scores based on consumer survey responses. The Ford Mustang Mach E ranked number one.
1. Mach E number one in reliability, score 93
2. Subaru Solterra - 90
3. Volkswagen. Id4 - 56
4. Honda prologue - 36
5. Hyundai Ioniq5 - 35
6. Kia EV6 -30
7. Tesla Model Y - 30
8. Chevy Blazer - 22
If it helps the OP the electric motor and drive system was rated best five out of five. I’m not defending Ford. I’m just relaying information. I would be very leery after his experience but it seems like it’s not a common issue at all. I’m not sure what year the OP has
Sidenote, I had a nephew who purchased a Mach E I believe in the first production year, possibly the second and it had to be bought back under the NYS lemon law. They just couldn’t get the charging right however he did get another one because he loved the car so much.
Good point, I'd stay clear. When the lease is up give the car back and move on is what I would do.
6. Kia EV6 -30
I will point out my two most reliable vehicles ever had low CR scores. Others on this forum have claimed the same.
I don't know how complicated the motors actually are but I wonder if they will be easier for the aftermarket to rebuild, assuming there is enough of a market to do so. I know it's more complicated than a regular motor winding, but... same idea, if there is enough of a demand to rebuild, perhaps aftermarket will fill the hole. That is assuming that the OEM doesn't make remans after a few years and the need is still there (not sure I've heard of an eCVT motor giving out?).
It almost seems like Ford tend to just do 95% of the work and then let the customers deal with the last 5%. Fusion hybrid for example, similar design as Prius eCVT but they have bearing issue in the motor / cvt? I mean it is really not something difficult to build as electric motors have been around for a long time and they manage to cut some corner and screw up.
Should have build in enough safety margin ahead of time instead of "latest mod" after the fact. Seems like Ford does that to their transmissions quite often (Taurus gen 4 AXOD with a snorkle for ATF vent, otherwise it would puke ATF in the middle of my garage).
6. Kia EV6 -30
This is why I never trust CR. They at one point rated Falken ZIEX 512 as the best tire and then everyone ended up having early problem after installation.
Or social media (forums)
By the way, tires are not the same as consumers reporting back on their vehicle reliability
I’m not defending consumer reports, just defending common sense. The OP and my nephew had an issue with a Mustang Mach E
Certainly not a valid sampling of the buying public versus every other electric vehicle on the market
Also, with common sense, we know as in the case of tires, consumer reports does not cut up and analyze tires. They report on the handling characteristic of the tire
Used to work with industrial motors. Most of the time if it is designed correctly and used in the right application it is designed for, it should last forever. If we ever had to rebuild it is usually refresh along with other things we have to rebuild, mostly gaskets and seals that got hardened over time. Our tech usually just take apart the ball bearings and inspect for scars, and clean up old grease (with isopropyl alcohol or other solvent) and apply for new ones.
Aftermarket rebuild without addressing the original problem would just wear it out again. Coil winding don't wear out if the power electronics are done correctly and cooling is not the problem. If the bearings are damaged you have to wonder if the aftermarket would use the same or better bearings. Knowing A1 Cardone rebuild axles they probably would just grind out the old heat treatment and put new grease on it so it won't even last as long as the original.
I didn’t know you had electric vehicles
Forums (social ) don’t come close to a statistically
fair representation of product reliability.
Not sure what you’re saying? You think CR can track EV better than ICE for some reason?
CR does not track reliability very long. They also rank all problems with equal weight - ie the interior light or ECU quit - same to them.
It’s been covered on its own thread here many times and seems most members here have the same experience that I do.
