Originally Posted By: NHGUY
Its probably Type F.Ford used that up until the 2000s,then went Dexron.
Good point, my 1996 Contour specifies Type F ATF for the power steering as did my old 1980 F-100. I still have the Contour and continue to use Type F with great results after 18 years. My 2002 F-150 spec's Mercon fluid. I'm using Mobil 1 ATF. It quieted down the Ford winter PS whine a lot.
Whimsey
