My sisters Lexus IS 300 Sportcross (wagon). It has the inline 6 Toyota engine. 70% city, 30% hwy in Miami, FL. I am pretty sure I used M1 SS (not EP) for this sample. I refilled with 5.6 quarts of M1 10W-30 EP. I also drained out 3 qts of trans fluid and refilled with T-IV as well as drained out the radiator and refilled with the Toyota Red coolant/distilled water. I think I will go with OCI of 7500 mi or 1 year.code:
Model Year 2002
Make Lexus
Model IS 300
Add'l Info Sportcross
Oil Type M1
& Grade 10W-30
Add'l Info SM
Sample Date 09/14/2005
Miles on Oil 6543
Miles on Unit 56510
Time on Oil 10 months
Make Up Oil 0.5 qt
Oil Filter Toyota
Air Filter Toyota
Testing Lab Blackstone
Aluminum 2
Chromium 1
Iron 5
Copper 3
Lead 0
Tin 2
Molybdenum 74
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 2
Boron 50
Silicon 15
Sodium 5
Calcium 2140
Magnesium 12
Phosphorous 594
Zinc 729
Barium 1
TBN 2.7
SUS Vis @ 210 F 63.1
Flash (F) 430
Fuel %
Antifreeze % 0
Water % 0
Insolubles % 0.4
Blackstone Comments: Universal averages show typical wear metals for an oil from this type of engine after about 4865 miles run on oil. Your oil was in use 6543 miles, and we found all wear at around average levels and in the correct balance to show normal mechanical parts inside. Air (see silicon) and oil (0.4% level of insolubles) filtration appear normal. This was 10W/30 engine oil with no fuel, moisture or anti-freeze in it. The TBN was 2.7 (additive left) -1.0 is too low. The oil could have stayed in use longer. Try 7,000 - 7,500 miles for the next oil change interval & sample.
