Hi
Is anyone using the Lukey Air Filter release in June 2007, its polyester upto 30kw rear wheel power just by changing the filter.
READ ON, web links are provided below.
Match for the EAA Amsoil Filters ?? Interesting?
Want to improve the performance of your car without spending a fortune? Then the new Lukey Performance Air Filter may be just what you're looking for. Lukey Performance Air Filters will give your car premium performance benefits by enhancing the air filtration process.
Air Filters work by cleaning the incoming air and ridding it of impurities such as dust, moisture and insects. Air is then mixed with fuel in the engine, so to protect your engine and ensure maximum performance, it is vital to keep the air-flow clean. Lukey Performance Air Filters are engineered using exclusive Ultra Flo Technology, which incorporates multiple layers of polyester fibres to form channels and guide the air through the filter for optimum performance and fuel economy…….......
http://www.lukey.com.au/default.asp?pageid=Products&template=CONTENT&sid=268
http://www.lukey.com.au/default.asp?pageid=NEWS&template=NEWS&nid=389&cnid=107
