Lucas Red overdose?
Central NY
Just bought a bottle of Lucas Red for the galant.
The box says add 1 oz per quart of ATF.
The bottle says "add one bottle"
will the 10 oz be too much for my 6.x qt transmission?
I do plan on draining 6 (or 10) oz first.
Also, since my PS fluid is spec'd for ATF, can i add this to the PS reservoir?
Don't worry about overdose. I've doubledosed Red to tone down squakey/chirpy transmissions.
Since I do believe it helps PSF, add 2-3 ounces to your power steering and the rest to your transmission.
will it stop PS leaks?
I should have my ARX tonight and was going to try that in the PS...however, if the LG will stop leaks (they both have esters) and i won't have to change it out, then LG gets my vote.
the reason i asked about the PS is because LG sells a PS version...figured it's the same stuff in a diff bottle.
