- Joined
- Oct 16, 2023
- Messages
- 75
I ordered our 2020 f150 I do believe it’ll need tires soon. The size is 275/55R20. Does ford run p or lt from the factory? What do you guys recommend? Can a p tire handle the capacity the f150 is capable of?
Since you're asking if the P tire will handle the load capacity of the truck you probably should put on what it came with. The door placard will tell you what came on the truck.I ordered our 2020 f150 I do believe it’ll need tires soon. The size is 275/55R20. Does ford run p or lt from the factory? What do you guys recommend? Can a p tire handle the capacity the f150 is capable of?
The truck hasn’t arrived yet so I can’t physically view the door place card.Since you're asking if the P tire will handle the load capacity of the truck you probably should put on what it came with. The door placard will tell you what came on the truck.
Where did you order a 2020 from?The truck hasn’t arrived yet so I can’t physically view the door place card.
Don't put the cart before the horse. Get the truck in your hands then evaluate.The truck hasn’t arrived yet so I can’t physically view the door place card.
But that’s no fun! it has highway tread on it and I know I wanted all terrains so I was weighing my options. I wanted to narrow it down so I could then do tire research. I work a ton and have a lot going on so it’s tough to find time to do tires. I plan on doing them this Friday since the shop will be closed and I’ll be able to go in unbothered and do them myself. That’s why I was putting the cart before the horse which I admit I was .Don't put the cart before the horse. Get the truck in your hands then evaluate.
Keep the highway tires and find somewhere quiet to do some burnoutsBut that’s no fun! it has highway tread on it and I know I wanted all terrains so I was weighing my options. I wanted to narrow it down so I could then do tire research. I work a ton and have a lot going on so it’s tough to find time to do tires. I plan on doing them this Friday since the shop will be closed and I’ll be able to go in unbothered and do them myself. That’s why I was putting the cart before the horse which I admit I was .
I'm fairly sure that running a "P" tire reduces the load carrying capacity. For a truck an LT tire is the way to go as don't most lt tires have more plies on the sidewall?I ordered our 2020 f150 I do believe it’ll need tires soon. The size is 275/55R20. Does ford run p or lt from the factory? What do you guys recommend? Can a p tire handle the capacity the f150 is capable of?
Ah ..... Mmmmm ....... Not exactlyI'm fairly sure that running a "P" tire reduces the load carrying capacity. For a truck an LT tire is the way to go as don't most lt tires have more plies on the sidewall?
