Don't they still use lubricants? I know they don't get the same level of maintenance due to lack of contaminants.I'm convinced there is only one way out of oil obsession - EVs. LOL
In a future generations, they'll argue about 240 V vs 1.5 kV charging. My grandpappy never went above 480 V and his batteries never failed. Yeah, but new batteries are designed for 1.5 kV charging. They have tighter clearances. Yes, but the manual for Mexico says they can be charged at 240 V. That 1.5 kV charging is just to meet CAFE2 regulations.Thick vs thin battery design.
I see a BITBG. Battery guy.Don't they still use lubricants? I know they don't get the same level of maintenance due to lack of contaminants.
We can start obsessing over the various gear or bearing oils used in EVs. Oh, we need a new "bob is the coolant guy" forum to discuss battery temperature conditioning.
Discussion on innovation starts at 15:48. Talk about metallurgy changes, hypothetical no need for deposit control and use of less ZDP with engines that use DLC. Re-thinking chemistry from ground up.
Thank you Sir.DLC is used as a way to allow the use of less than robust lubricants. As expected, the DLC has a limited lifespan.
Wasn't that the whitesnake song ?Here we go again with LSJr.
Some of those M1 oils have Zinc levels which are creeping up towards 1000 ppm.Not all forms of ZDDP and moly attack DLC the same and not all DLC are created equal as well, so it's complicated and probably requires case-by-base validation and why the C40 GT specification was necessitated in the first place.
