I have a 2009 Dodge Ram 1500 with the 5.7. Alot of members are running 180 degree thermostats vs the stock 195 degree. There current oil temperature was 204 degrees with the stock 195 thermostat and as soon as they put in the 180 thermostat the oil temps went down 16 degrees. My question is what are the pros and cons on installing a lower degree thermostat? and is 204 degree oil to hot? thanks in advance
