- Joined
- Nov 29, 2009
- Messages
- 9,523
It seems like the zero fittings are clogged. Should I just replace the zerks?
I used to take a rag and clean the fitting with Fantastik or 409, and then I would just poke the fitting with a skinny screwdriver.It seems like the zero fittings are clogged. Should I just replace the zerks?
Changing those fittings would be my first step. There may be enough grease in there to last a long time. I wouldn't replace the joints till they get loose or start making noise.It seems like the zero fittings are clogged. Should I just replace the zerks?
Why bother with buying specialty grease zerc tools when the zercs are simple to swap out and are cheap and readily available at any part store..
That's what I was going to ask. I bought some once and the once I bought didn't really want to thread In.
