Low Tire Pressures
The op pointed out the difference between inflation pressures as affected bt tire temperature. No surprise, he set them when they were hot after highway driving, then found the pressures low I'm guessing with the tires cold.
Is it worth getting into a urinating contest over this?.
Claud.
Originally Posted By: oil_film_movies
...... In summary: The B-pillar placard temperature is really the 70 deg F pressure. ......
I think this is the quote that best illustrates the problem. I now know you didn't mean it the way it was written.
Checked the tires on the Toyota tonight the pressure was down about five pounds. Fall is here and those lower temps make a lot of difference they were all down equally. I aired them up and should be set until we have our first freeze.
