Is there any reasoning that owners of cars using high viscosity motor oil, should stay away from low micron filters for fear that flow may be restricted or the may filter by-pass the media during cold starts ?
Only time to worry about that would be in very cold start-ups with thicker (higher "W" rating) oils. The way to mitigate excessive delta-p across the filter and therefore filter bypassing is to keep the engine PRM low until the oil warms up. At operating temperature, there is no concern because the viscosity difference at 100C between 20 and 50 is very small.Is there any reasoning that owners of cars using high viscosity motor oil, should stay away from low micron filters for fear that flow may be restricted or the may filter by-pass the media during cold starts ?
If you're worried about it, then get an oil filter that is both efficient (if you want efficiency) and also flows very well. They do exist.We do not know when a filter goes to internal by-pass. My fear is that if a low micron filter were to go to by-pass mode more often than a regular, say 30 micron filter, does that possible wash from the dirty side negate any benefit of getting a low micron filter in the first place ?
Not necessarily. Many new engines like the Corvette spec 0W-40, and it's not because of loose engine clearances. Those engines are just as tight as any of them.Also would an engine requiring, say, 20w-50, typically have larger operational clearances that might better tolerate particulates ?
All the K&N range will do the job or you could run a fram racing filter with 94% efficiency at 20 micron which is likely better than the K&N's. I'm swapping over to the fram racing filter because they are about the same price as any decent filter in Australia. I run 50 or 60 grade in a modified turbo vehicle.Thank you for that.
pity there were not more filters in the comparison.
The filter goes into bypass when ever the differential pressure exceeds the approximate by pass valve rating. Starting the engine would be a great example. Yes all cold oil is much "thicker" that oil at the engines stabilized operating temps.We do not know when a filter goes to internal by-pass. My fear is that if a low micron filter were to go to by-pass mode more often than a regular, say 30 micron filter, does that possible wash from the dirty side negate any benefit of getting a low micron filter in the first place ?
