Hey Everyone,
I'll try to break this down as simply as possible but I do have a ton of questions. So basically I want to buy a set of 18 inch aftermarket wheels but I'm confused about offset. So my stock wheels have the current dimensions 18x7.5, bolt pattern 115, and an offset of 48mm. And the tires I have now are Toyo Proxes 4 Plus 225/45 R 18 W.
I was looking to buy these wheels specifically because they have the same offset -
http://www.tirerack.com/wheels/WheelClos...h=Black+Painted
But according to Tire Rack the factory TPMS sensor won't work and I need to purchase new ones costing me $200 bucks without programming. So I found this set instead which I also like.
http://www.tirerack.com/wheels/WheelClos...;autoModClar=SE
But it comes with some kind of lug nut adapter which I'm also confused about. So I guess, what are my options and what should I stay away from? I know the wheels I like are 18x8 but I think a 225 width tire would like fine on that size rim.
Thanks,
Swift
Thanks,
Swift
