Looking for a filter.
Illinois
I need a filter that has a 3/4-16 thread, is less than 3.75" tall, has the normal ~3" base.
But it needs to be a high pressure bypass, around 20 lbs.
I'm replacing the OEM Hyundai filter and they have the 20 lbs bypass. Sometimes there are issues if you don't stay in that range.
Currently thinking about the Motorcraft FL-910S as it is the right size but comes in at 14.5 psi bypass. The FL-400 is too long.
Because my OEM filter has a 20mm thread. I am adding a Ford oil cooler that takes a 3/4-16 thread for the filter. The Ford cooler has a 20mm thread to screw into the OEM oil filter adapter.
That looks god. I'm not really sure of the exact length I can go to. And 30 psi certainly is good enough.
The OEM filter is 3" long and the oil cooler is 2 5/8". I mocked it up last summer and that combo worked good for fit.
