J John-r Joined Oct 19, 2003 Messages 49 Location Michigan May 18, 2008 #1 What is the best oil to use in the hydraulic system of a log splitter, I've heard you can use hydraulic oil or dextron transmission fluid (ATF) Last edited: May 18, 2008
MolaKule Staff member Joined Jun 5, 2002 Messages 24,036 Location Iowegia - USA May 18, 2008 #2 An Anti-wear hydraulic oil is best. For your area, an ISO 32 or an ISO 46 AW oil should work well. Grease the slides with a #1 or softer grease and it should give you many years of service.
B badnews Joined Jul 31, 2003 Messages 848 Location Ohio Jul 7, 2008 #3 You can use automatic transmission fluid if hydro fluid is hard to get
J jrb Joined Dec 23, 2008 Messages 4 Location California Dec 23, 2008 #4 Tractor hydraulic fluid works well. Most of them are Multi-viscocity
