So the wife loves having a cordless stick vac for quick pickups. Our Hoover Linx's battery went on the Fritz, so she got a Dyson V6 on Black Friday last year. While I'm not a big fan of these toy vacuums, she likes them so I don't fight her on it.
Part of the reason I didn't just replace the Hoover's battery is because it cost $60+... not worth it for a vac that you can get for $80 on sale. So I decided to fix it myself.
I took apart the battery pack. As suspected, it was 5 18650s in series for 20v nominal voltage. The batteries were Sanyos and all were reading a discharged state of 3.2v except one that was 2.6v. That was my culprit. After a little research I found that the Sanyos were UR18650W2 with a relatively low 1500mAh and 15A discharge.
I picked up 5 Samsung 20Q 18650s with 2000mAh and 15A discharge for $3.50/ea. I almost picked up the 30Qs which are 3000mAh with a 15A discharge, but those were $7/ea. which defeats the purpose of a "cheap rebuild". Tonight I popped out the old batts and soldered in the new ones. Worked like a charm!
I know that you really shouldn't solder on 18650s because of the potential for heat damage, but I moved quickly and I think it should be alright. I'm working on creating a low voltage/high amperage battery welder from a microwave transformer, but that project isn't done yet. So solder it was.
I don't have pics of the after, but here is the battery sled disassembled as a before. Just an encouragement, pretty much anyone can replace 18650 battery pack cells. Just be careful not to short and vent them!
