Startup wear on cool/cold morning...again, how ?...0W isn't needed until quite a few 10s of degrees below zero...."cool" mornings, 10W, 15W, and 20W will not increase wear...with a PD pump, well into the pumpable range, they all get there at the same time.
No, VII only works at warm to hot temperatures, increases visc there. Remember 0w20 is made with thinner base oils than 5w20.
Also, there was a study showing that as long as startup visc is different, startup wear is different. That engineering study already refuted debunked remarks by you in another thread, yet there you go again. ...0w20 and 5w20 differ in visc below about room temperature as the VII becomes less effective.
