Features and Benefits :
Fabricated Steel Lift Arm, 50-1/4" L Handle For Less Lifting Effort, Crowned Rear Swivel Casters, Automatic Valve Prevents Overloading, Removable Saddle For Use w/ Transmission Adapter & Removable Handle, Raises Lift Cap to Load in 1 Stroke
Attributes :
Jack Closed Height : 4-1/8"
Jack Lift Distance : 15-5/8"
Jack Raised Height : 20-1/4" (w/ Rubber Pad)
Jack Saddle Diameter : 5-1/2"
Lift Capacity : 3.5 Tons
Unit Weight : 119 lbs
Air Operated : No
Dimensions : 29-3/8" L x 15-1/4" W x 6-5/8" H
What are they talking about? Do they mean that once you roll the jack under your car that it only takes 1 pump to get the pad from the resting position to the spot where you want to lift from?
