I started this as a new thread even though I posted this on page 2 of an older thread. I wanted to experiment with a 10,000 oil change and installed Mobil 1 5W-20 in my 2006 Lexus RX330. At 5900 miles on the oil (the vehicle has 41000), below is what Blackstone said. I'm disappointed and wondering exactly what's going on. It's possible, I guess, that the prior oil change at the dealer (with my oil) didn't drain all the oil or didn't change the filter, but they've generally been a good dealer so I can't assume they goofed. Any thoughts about this:
"Universal averages show typical wear for this type of engine after ~6,100 miles, so your wear metals are a little higher than average, but only lead (from bearings) is high enough to highlight. Silicon or sodium may show the cause; neither one is an additive in Mobil 1, so unless these are residual from a
previous oil, silicon might show dirt and sodium might show antifreeze. Neither is a big problem yet, but better to catch it early, so check the air filter and watch for a coolant leak. The TBN is good, at 2.8 (1.0 is low). Change this oil and check back in 6,000 miles."
