Learning about VLANs
Nokesville, VA
I have two switches, a Nortel Networks Baystack 450T and a Cisco 2950, and I thought it'd be educational to configure a VLAN trunk port on each one, connect them, and set up two VLAN access ports.
I got it working. The VLAN access port for VLAN 2 on the Baystack is connected to the firewalled ethernet interface on my Linux machine which runs it's own DHCP server.
The VLAN access port for VLAN 2 on the Cisco is connected to my wireless access point.
VLAN 1 is connected to my broadband router and the unfirewalled interface on the Linux machine, as well as my 3 desktop computers.
I ran tcpdump on the firewalled interface (connected to VLAN 2) to make sure everything was working right (ie, traffic from VLAN1 not getting to that interface) and when I did a ping to a nonexistent local IP from my desktop machine I saw the ARP requeest. Uh oh...
..it turns out that the access port that the Linux machine's firewalled interface is on was a member of both VLANs, apparently a configuration that Cisco doesn't allow but the Baystack does.
I fixed that and did another ping to a nonexistent local IP and didn't see the ARP request so all is good.
I have to say, I like the user interface on the Baystack much better.
We use VLANs extensively here at my work. We have three different server environments, each with an internal network segment and a DMZ, an internet connection, a main lab, two office floors and a soon-to-be-connected remote office. Each has it's own segment and various segments are firewalled in different ways. We have one Cisco 4500 switch at the heart of it all with 3 firewalls and several T1 routers. It's amazing what that one Cisco will do and VLANs are the reason that's all possible without a dozen more pieces of network gear than we currently have. It's a very powerful box.
You should be able to have multiple tagged VLANs on 1 port, but not multiple untagged ports. FYI on the newer Baystack (now Nortel) equipment, this would not be allowed either. Try a firmware upgrade for your 450T.
Think of a VLAN as a virtual Layer 2 network.
Unfortunately Nortel doesn't make firmware updates available without a support contract.
Interestingly, even the latest revision of the manual for the Baystack 450 (which they do make available without a support contract, how nice) talks about how you can put an access port on multiple VLANs. The example shown has a network printer plugged into the access port, with two VLANs having access to it.
