AT pan was leaking following switching to syn. Took it to the transmission shop and they noticed the different bolts and washers all over snd determined the previous shop stripped the screws when the transmission was rebuilt. The transmission case is aluminum and the bolts are iron I think, or steel. I am bringing it in on Monday to be fixed. He will be using Toyota's "make a gasket" on the pan instead of a cork or rubber gasket. My question is...can you even re-tap aluminum and how well can this be repaired. WHAT A PAIN IN THE A$$!!
