A while back I started noticing drips under my 18 month old Silla All aluminum radiator.
They only make it to the ground if the Vehicle sits for 12+ hours, and rarely make it above the 2.5 inch diameter mark on asphalt.
I've only added about a half gallon of distilled H20 to the expansion tank since I noticed the leak about 1 k miles ago.
I do smell evaporating coolant if the wind blows right and my windows are open when at a traffic light.
I am mainly an around town driver these days and most trips do not even get the coolant up to full temp before I reach my Destination though I do weekly make sure to do a 20 minute highway run.
Obviously I would like to replace it, but money is tight and work sparse. I'm never doing another internet radiator, and everything local is a plastic tanked aluminum radiator in the 200$ range, or copper brass in the 300$ range.
All my previous copper brass radiators had the leading row of copper fins disintegrate within 2 years due to my salt air environment, while my aluminum transmission cooler showed no issues, which is why I tried aluminum this time.
The rate at which it is seeping does not seem to be increasing. I did go from a 16 PSI cap to a 13PSI.
Is the radiator likely to go all at once, or can I just keep monitoring it and adding Coolant it to it until I can afford a replacement?
It has required a good amount of effort not to just put some aluminaseal or similar product in it. I did replace all the other cooling system components at the same time as the radiator and would rather not add this stuff unless it were an emergency.
Thanks for your experienced opinions on this matter.
