The recommend dose of LC it 1oz per qt. then 1oz every 1000 miles and they recommend an OCI of 10,000. My question is, if i am only planing to run 3000-5000 mile OCIs can I just add the 1oz per quart at the oil change and not add LC every 1000 and still get the benfits or performance that LC advetises. Reason for this is i am trying to use LC as a maintance product but am trying to make the gallon last longer and also it is easier to just add it in at the change and not worry about having to add it in every thousand miles (PITA especially since i add FP every tank too). Plus there is less chance of it thining out the oil since your not using as much. So basically my question is how long will LC last & perform and keep my enigine clean if I only add it at the oil change? Seems like i am always in the garage adding either LC or FP and i am trying to see if i can get the benefits of both products but not have to add them as often. thanks for the help.
