I did a search on this and came up with a few answers, but I want to be sure.
1. What is the total amount of time to use LC as a flush? (Last # I found was 20 minutes at idle)
2. Normal idle or fast (2x normal) idle?
3. I have a 5 qrt sump so is 16 ozs the correct amount?
4. What do you think of splitting the 20 minutes into two separate running times (ie: 10 minutes the evening before day of oil change and then another ten minutes before draining oil)? Why? To get the LC circulated and soaking overnight.
Story: Engine: 3VZ-E. I didn't know I had a clogged PCV which caused a lot of carbon buildup (oil burning) in the crankcase. Did a full 2 bottle ARX treatment then switched to Mobil 1 10w30 (still not knowing about PCV, mind you). Still kept burning Mobil 1 and then finally found the problem. I did another full 2 bottle ARX treatment with Mobil 1. The Mobil 1 is still turning dark after only 4K and I'm thinking there is still garbage in there that needs to be cleaned out.
I'd like to try an LC flush before switching back to dino for another ARX run.
