Been curious for a long time about using LC 20 in my oil tank in my bassboat. I like the way it has worked for me in my trucks. question is what amount would I use per gallon of oil that is being injected into the motor and being mixed with the gas. the ratio is 50:1 . looking at the LC website it says use ¼ oz. or 10 cc per gallon of Fuel/Oil mix is sufficient for this application. so is this 1/4 oz per gallon of 2 cycle oil ? if that is the case then I would only add 1oz to my 2 gallons of oil that I usually run in my remote oil tank. was also thinking I could do a piston saok to clean off the tops of the pistons then just run the FP 3000 in my gas from there. any suggestions ? I currently run either seafoam or ringfree in the gas.
