I am working on Bendix drive from Husqvarna riding mower. The Bendix drive had mouse nest material wound around the Bendix drive. Cleaned it all out with a toothpick and tweezers.
The shaft is nylon.
Question is should the spring push the gear back down when the starter is out and I move the gear up by hand and let it go?
No lubrication on the shaft since it's nylon.
The shaft is nylon.
