I hate doing tie rod ends. This part of Kentucky uses just enough salt in the winter to make this job a real chore on a 25 year old car, but not enough that your car rusts away in front of your eyes.
This was pretty much a last ditch effort as all other attempts at heating, penetrating oil, 1/2" impact, etc. all failed. Made some not-so precision cuts in the nut, being careful not to go too deep and ruin the threads. Then stick a screwdriver in the slot you made and pry the two sides apart. Didn't think it would work, but it was actually quite easy. I still nicked a couple threads in one spot, not enough to hurt anything. I'll run a thread chase over the whole thing to clean rust and it'll be good as new. I figured the worst thing that could happen is that I'd be out a $30 inner tie rod, but that's still cheaper than taking it to a mechanic, which is just putting the problem on someone else. Not sure what else they'd try that I hadn't.
Curious what other tricks there are to remove these jam nuts that I hadn't thought of...
