Laptop Battery Problems
High Desert, California
Dell Inspiron 600m (1.6Ghz Pentium M)
Purchased the laptop near Christmas of 2004. Since then it has been on an average of 8+ hours everyday. 99% of the time it has been plugged in. Only a handfull of times did I use it without the power cable and let it get close to 10% battery left.
At work last week Friday - I accidentally forgot to plug in the power supply and noticed that about 5-6 minutes after powering on the laptop it turned off at a pre-set shut down when the battery gets to 3% life left.
Well, yesterday and today I tested it out - the battery lasts anywhere from 5-12 minutes before shutting down to standbye. This morning I kept track - the last I saw before it went off was 80% battery left with 2:25 hours left. Looked away for a few minutes and boom - laptop off.
Do I need a new battery?
Co-worker suggest I try several drain & fills to revitalize the battery ("worked or his laptop"). I thought this only worked with the older nickle cadium batteries with memory effect - Lithium Ion isn't supposed to have a memory effect, no?
Thanks for your help, comments, experiences -Paul
Went over everything - looks to be ok... I noticed that the when Running on batteries - turn off monitor: After 30 minutes and Turn off Hard Disks: After 30 minutes. I don't think I ever got close to 30 minutes though.
Talked to another co-worker and he said his laptop is doing the same thing after the laptop aged 2+ years. His new laptop (1 year old) only lasts 1 hour compared to 6+ when he first bought it. He was saying something about keeping it always plugged in really hurts the battery and you should be draining it / filling it regularly to keep the battery happy.
Interesting.
I have same issue with older Toshiba. I ran the a toshiba battery utility where it drains then charges the battery. I used it an worked a few times when my battery would no longer fully charge, but now I need a replacement. Looks like your supposed to utilize the battery instead of treating it like a desktop. If I knew about the Toshiba utility long time ago I would have been using it regularly
yeah, one thing that I always do is take the battery out if it's plugged in, and if I'm charging the battery and take the battery out asa it's 100% charged.
also, I can almost double the battery life by turning down the brightness of the screen by half...
Good idea 97tbird - thanks for the info Trucku. I'll have to remember this for my new laptop when I get one.
My dell laptop's battery has one of the laptop's supporting posts to the ground on it - so if I take out the battery the laptop leans off to the side - lol - oh well.
Yeah 97tbird - I remember when I first got the laptop - turning down the brightness took the life from 5hours to about 7.
Pretty interesting how much power those screens use even though they are LCD.
I have a Compaq V2000. According to instructions HP provided, once a month the battery is to be fully discharged and a calibration procedure followed (if battery is rarely discharged fully with normal use). I started this late in the game, but now am on a regular schedule. Also, it says to remove the battery from the notebook if plugged into AC power continuously for more than two weeks. I use mine enough at work sites to use it unplugged every week or so. So far, the battery seems to have full capacity/time after one year. It seems like every computer manufacturer would list battery care practices at their website.
If you really want to go to the trouble to prolong the life of a LiIon battery: Store it in a cool place at ~40-50% charge status. Avoid discharging it below 10% at any time. The only thing worse than storing a LiIon in a hot plugged in laptop is freezing it.
So why is HP saying to discharge the battery? I was under the assumption that it was for longevity, but maybe that part is more getting a accurate battery calibration. My battery will cost $150, so I would like to prolong its life.
Did this utility come on your machine or can it be downloaded?
