Originally Posted By: Ducman
I honestly don't see anything abnormal about his wear numbers.
I'm thinking the wear numbers are too high for a 1000 miles on the oil.
IMO, It's impossible to determine anything from a single UOA.
Especially on the first one when the engine may still conceivably be running in.
And it's a total unknown how long the air was being unfiltered.
With regard to the air filtration issue. The amount of Silicon in the oil is quite low.
That's why I believe there's nothing to see in this instance.
It is a requirement that a baseline and trend is established, for anything to be drawn on this potential "non issue".
For all we know, this could be normal for this type of engine in a severe service application, due to the very short trips. The engine rarely if ever gets to normal operating temp.
That's the only big issue which is patently obvious at this point in time.
It's all speculation other than that.
If it was me.
I would continue with the current oil or change to an Amsoil equivalent in the current grade, then go forward with regular used oil analysis at "appropriate service intsrvals" to get a picture of what's normal.
Then determine if I would like to/can improve on the wear metal situation by experimenting with different grades when it becomes clear what's normal.
