My BX2350 recommends oil changes every 100 hours. I generally change the oil in the outdoor equipment I use all year in the fall (so the acidic byproducts of combustion don’t remain in the crankcase too long) and again in the spring (in case the crankcase contains any condensation from operating in a cold weather environment). I will not use the tractor for a full 100 hours in either season. Is it recommended that I stick to my regular routine of fall and spring OCI or use the Kubota 100 hour OCI?
