boraticus, I think smaller engines with less power are more susceptible to overheating from heavier oil as a greater percentage of their meager output is eaten up overcoming the drag of their lubrication system … others could probably answer this better. There are probably a number of factors involved with this phenomenon.
To everyone else, I understand the concern about pour points. Since this has come up before, I attempted to put together a list of various brands and the pour points for their SAE30 vs. 15W-40 but the data I found was terribly inconsistent. Some manufacturers had identical pour points across a whole range of viscosities, others had wild swings of 40 or 50 degrees between 30 and 15W-40 ... which I found impossible to believe.
Looking again just now, a reasonably consistent source I found was Valvoline:
http://www.valvoline.com/pdf/afpud.pdf
The 15W-40 has a 6C degree advantage (10F) over SAE30. That’s not a world of difference … but it is significant.
I must stipulate though, that I stated I had used 15W-40 in a snowblower above. That was correct … but it was a unit that was stored in a heated house garage. Another snowblower, stored in an unheated, detached garage used either synthetic 5W-40 or 10W-30 (I’m not sure as it was a handful of years ago). I would not use a 15W-40 in a unit that would regularly be started and run in temps 25F and less.
