I've noticed that when I switched from conventional oils to Mobil 1 years ago, the smell I got in my car after an oil change (oil dripped onto the exhaust) was more intense and lasted longer with the synthetic.
I attribute this to the synthetic's resistance to burning off compared to mineral oils. The same explanation
may explain the more noticeable color you see coming out of the engine. If the oil getting into the cylinders combusted more completely, it's color would probably not be the visible blue you see. I'm pretty sure the blue comes from oil particles which has atomized but hasn't really combusted.
Mobil 1 (Group IV synthetic) will flash off and combust at higher temperatures than mineral oils. It is likely that the combustion chamber conditions are insufficient to burn this stuff cleanly.
Since you are saying that consumption seems about the same with both oils, that's the best theory I can come up with.
All oils consume at least a tiny amount of oil and I wouldn't worry too much about it. If consumption increases and/or spark plug fouling becomes a problem, consider trying to get a replacement motor. Just save all pertinent documentation, etc ...
Bror Jace
