JHZR2
Staff member
My 91 318i has its original clutch at 140k. Both myself and my brother learned on it, it sees regular use, lots of stop and go, traffic, etc. My 9 mile commute has a ton of lights and a toll, so I do a lot of clutching.
Today for the first time, I felt that as I engaged the clutch, especially first from a stop, that as I hit the clutch point, that I had friction, then not much then slam and I was fully engaged. Not sure if this was really the case, if I was doing something weird or what, but something was noticeable. I've been driving this car for nearly 10 years, so it stood out a bit..
Then, after driving a bit, like so I was warmed up and had used the clutch a bunch of times, it went away. Weird.
Is this a sign of a clutch going? Hitting throttle hard doesn't cause revs to fly up or anything.
Also it went away...
Can a leaking rear main seal get oil on the clutch somehow, causing a slip until it burns off?
Also what are the signs of a master and/or slave cylinder going bad? Can you tell by irregularities in clutch/brake pedal feel or action?
Thanks!!!
Thanks!!!
