Kendall GT1 Synthetic Liquid Titanium 10w30
Tn
Thank you for the post. Ti won't be a problem for UOA reports unless you have titanium pistons, rods, or cams like some supercars do.
Thanks. If you dont mind look at my used oil analysis in the Gas used oil analysis section. Im worried that over several o/c the oil that does not drain out of the engine will tend to let the ti continue to creep up. Virgin oil has 60ppm ti and over 2 o/c the ti is up to 80ppm. If this trend continues what will happen if ti gets up around 150-200ppm. Im thinking this could cause issues from residual oil in the engine. Not sure though just curious
I've heard of titanium rods, but I seriously doubt there are pistons made from it.
Some modern production cars use titanium connecting rods and valves. I have never heard of titanium pistons and cams in production engines. Drag racers experimented with Ti pistons back in the 70's, but they didn't work. WoO sprint cars were using Ti cranks in the nineties, but those were outlawed due to cost.
The PDS for Kendall GT-1 lists the TBN as 9.5. Whether the PDS or VOA is more accurate, does 1.4 TBN matter?
The TBN for GT-1 syn is 8.6. It's higher for the 15w40 HDEO, or the 5W-40 Euro oil.
Little suprised by this UOA...thought the ti replaced the moly and boron......
Look at http://www.conocophillipslubricants.com/documents/conoco/industrial_oils/Ken%20GT-1%20Full%20Synthetic%20MO%20(Ti)%20TDS%20Web.pdf
MUST be
Phosphorus: 720 ppm (instead of 427ppm)
Zn: 850 ppm (instead of 514 ppm)
Titanium: 100ppm (instead of 54 ppm)
