Originally Posted By: jsharp
I understand. I've always felt the same way. I wonder though, if the wear numbers look good does it really matter? Here in the M/C section there seems to be a lot of worry about it, almost to the point where viscosity retention takes precedence over the rest of the report.
I certainly don't think that that's the right way to look at it.
I agree with you on the wear numbers. Logic would dictate that no wear is a good thing no matter what the viscosity is.
I may be the biggest pile stirrer on the viscosity thing. Mostly just to poke Amsoil in the eye. Amsoil went through a lot of trouble to put together a white paper. In which they tout their stbility. Only to find out it shears in applications where the engine and transmission share the oil. And gets thick in a Twin Cam. If I use that against them, I have to be fair and use it against the other brands as well.
