I have a 1996 V6 Ford Contour. The reason I decided to try Auto-RX is that it has an oil leak from somewhere above the oil filter that drips along the filter and then onto the exhaust Y-pipe, making quite a stink. I think it's the head gasket because the leak is from somewhere below the valve cover. It's not from the oil pressure sender.
There is also a leak from the rear mail seal. None of these are bad enough to leave spots on the driveway.
I suspect that this car had probably been neglected--I am not the first owner of it, and when I checked the emissions test records on the Virginia DEQ website, it showed that the vehicle was driven 3000 miles in 2 years and then failed an emissions test with excessive NOx, probably due to the carbon from the short trip driving it likely had been used for during that time.
The most recent emissions test was it's best ever, mainly because I replaced both oxygen sensors and sprayed half a can of B12 Chemtool into the throttle body with the engine running--this cleaned the intake manifold and the combustion chambers and probably the cats too. At 15 and 25MPH the test recorded 2PPM NOx--this was at 98,000 miles. I have NEVER seen a car get this low of a reading on the NOx.
A couple of weeks ago I changed the oil with Mobil Drive Clean 5w30 and the filter with a Motorcraft FL-820S. I added 14 ounces of Auto-RX.
A couple of days later I washed the engine. I sprayed Scrubbing Bubbles Bathroom Cleaner (yes, believe it or not it works very well for cutting grease and oil) onto the front of the engine and hosed it down.
As of yesterday night the Auto-RX has been there for 500 miles and there is NO oil on the end of the filter like there normally would be. I also haven't been smelling the stench of oil burning like I used to. The rear main seal still looks like it's leaking but it think it might not be as bad as it used to be.
I will continue to run the Auto-RX for 1500 miles and then do the rinse cycle and then do the second application as the instructions state. I will be interested to find out if the rear main seal leak goes away. Currently the car has 101,100 miles on it.
