Originally Posted By: daves66nova
Is this a decent one? I mainly use it for the kids,no serious viewing.I do want to be able to use comp at the same time.http://cgi.ebay.com/ATI-RADEON-9250-256MB-DUAL-DVI-VGA-TV-PCI-VIDEO-CARD-/250827154644?pt=PCC_Video_TV_Cards&hash=item3a6676a4d4 ,or
http://www.outletpc.com/cg7422.html
The one on outletpc.com isn't going to work for you. Its a PCI-e (2.0 x16) interface. That old Dell only has PCI slots. PCI for all intents and purposes is dead as an interface for anything more complicated than a network card, sound card, or firewire card.
The ebay card you listed has no mounting bracket, so um... might be a bit difficult to install seeing as nothing will be holding it in but the friction from the PCI slot. Also no HDMI out on that card. I see a VGA, S-Video, and a DVI connector, so you'll need a DVI to HDMI converter such as
http://www.amazon.com/Link-Depot-Male-DVI-D-Cable/dp/tech-data/B00180F402
The ebay card despite it being listed as "dual", I'm not sure it is. Googling the part numbers shown in the pic of the card I found some results, but none indicate it is capable of dual feed meaning what you see on the TV is what you see on the computer and vice-versa.
And as someone else pointed out, even if you manage to get a PCI dual head card that Dell isn't going to be able to handle dual feed (at the most it has a P4 but might have only a Celeron) so you're not going to be able to use the computer if you're watching Netflix. I also wonder if your power supply could even handle that cards power requirements since that Dell was shipped with a PS that is just enough to power what came from the factory.
http://www.outletpc.com/dq8953.html is a PCI card but again no HDMI, just DVI so you need the converter cable again.
Also DVI doesn't carry audio like HDMI does so even using the DVI to HDMI cable you're going to have to find another way to get the audio to your TV as the video card isn't going to output any sound over that connection, meaning you'll have to run a cable with the appropriate 3.5mm mini-jack connection and RCA connections from the sound card to the TV so there's a $10 or more for that cable.
Here's the cheapest PCI with HDMI out card on newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131325
Even if you do get a PCI card with an HDMI output, you're not going to get sound out of it too like you would with an HDMI connection from a DVD or Blu-Ray player as those old PCI cards do not come with the built in audio decoder to send the audio and video signal over the HDMI cable because PCI is an old old standard and simply lacks the bandwidth.
Basically,
either get a roku box or a Blu Ray player with Netflix capabilities as has been suggested several times.
Or give up on the idea of streaming Netflix.
That old Dell isn't going to handle what you are attempting to do. I know you're trying to go the cheapest route possible, with just tossing in a video card, but it isn't going to work with the hardware you have and by the time you get done, you're going to have spent nearly much as a roku box or a Blu-ray player.
