TheTanSedan, thanks for your reply. I too have added LC to the PS and ATF though I had reservations about adding it to the ATF since I run Amsoil synthetic ATF there, but I thought if it helped cleaned things out then it would be worth while in the long run, and adding longer life to the transmission fluid is a bonus if that holds up.
I havent notice any improved shifting with the addition of the LC but in all fairness I run a shift controller on the transmission too which boosts the fluid pressure to make the shifts a bit more snappy and less dragged out like it was when I got it, so I think if there were any improvement the firmness of the shifts already may mask any difference.
As I mentioned if LC reduces the oxidation and nitration numbers and keeps viscosity in check on the Amsoil 0W30 then I will consider it a success. If it does any more than that like help clean out the internals, well thats just a bonus. If it accomplishes the two things I seek of it I will buy more. Im already planning on buying more FP. Even if it does not increase mileage I would still use it because of how responsive it makes the motor and the peppiness it has.
I do used oil analysis about every 8000 miles or so, so if LC is going to make a difference I should see it shortly, Im probably 4k miles from my next UOA and I drive roughly 500 miles per week if not more.
As to the software I use for maintenance and fuel tracking its called Auto Maintenance Pro and can be found at the below link:
http://www.mtcpro.com/automtc.htm
Its $50 but its by far the most comprehensive package I have found and in my opinion worth every penny. My hope is that if I should ever part with the car (and right now I love my ride too much to consider it) that I can hand over a very well documented maintenance history to the next owner and perhaps ease their mind a little.
Im not an additive person by even the wildest stretch of the imagination and I love Amsoil and will probably never use anything but. However, I try to keep an open mind about things as much as I can and after reading all I have on BITOG about LC and FP I felt I needed to at least give it a shot. At the worst, it does not work and I change out my fluids and start over. At best, its the perfect compliment to Amsoil synthetics and my fuel system and I have come to possess a product that will help me keep my ride around even that much longer.
