I deliver mail part time in my 93 S10 Blazer 4x4 so it gets beat up a lot especially on the right side as I go off the payment constantly to reach boxes, go in small ditches, pot holes, etc.
A couple of weeks ago I heard a 'pop', not like a tire but something else. When I would turn it would pop again. Come to find out I busted the lower RH lower ball joint. Also it would pull HARD to the right. If I let go of the wheel it would be off the road in about one second literally.
They are factory ball joints so you have to grind off the attachment/rivet/whatever to remove. A local tire shop (which does great work) said you need to replace both sides at once and also my idler arm and pittarm were worn. $514.67 to replace both ball joints, arms and alignment.
I work part time so it would have been difficult to pay that out right now. I know a 'good 'ole country boy' who has worked on Chevys probably since he could walk and could do the work blindfolded. BUT instead of just lowers, he recommended to do upper and lower and both sides due to the age. I bought the parts and he did the work for $100.
So he finished the job and I drove it. The pull to the right did not change. So he and I look and we definitely could see the front RH tire pointing to the right a little and the LH was straight. I know you can't align a front end by eyeballing it, but this seemed obvious so he tried adjusting it very slightly until I could get to a shop for a real alignment. No change.
On the 4th since I was off and wanted to see my dad, I went to Columbia, TN and figured I'd drop it off at a place and while waiting visit family. I shouldn't have drove it 2 1/2 hours in the condition it was but I called that morning and a few shops there were open and NOTHING even close to me was. And I HAD to work the next day so figured it was the best option.
My dad recommended Expert Tire, he buys all his tires there and gets alignments done. Drop it off, about 4 hours later they call and say it's done. I leave and immediately notice there's ZERO change in the pull. I'm ticked. I go back and sternly ask did no one drive it after it was done? He said they don't drive them typically and showed me the printout where it was BAD out of alignment but now was all within spec.
So he says they need to swap the two front tires and then drive it to test again to rule out the tires. As the guy puts it on the rack he calls me out there and says he's sorry for missing it the first time but my LEFT tire was bad. I looked and couldn't see anything wrong then he spun it by hand and it wobbled. He said they call it a pregnant tire. But the bulge covered HALF the tire and was not huge so you couldn't really see it until you saw the wobble it made.
I had them put on my full size spare, then drove it and it was the best drive I've ever had in this vehicle since I bought it a year ago. Apparently the tire had been bad the whole time but initially just caused a rough ride, which I attributed it to being old shocks or stiff springs since it's a 4x4 (first 4x4 I've ever owned). And by chance it got worse when the ball joint broke.
Man it drives like a dream now. I can let go of the wheel and it won't even think about leaving the road.
I wish we had a Expert Tire or Firestone close to where I live (they are affiliated somehow) as I would have gotten the lifetime alignment.
So, I got another friend who's dad owns a used car lot and gets wholesale prices at Advance, and got all the parts mentioned above for $98 and some change. $100 labor to install. $69.99 for alignment. $547.67 - $267.99 = saved $279.68. It pays to shop around
